Tomos ST and Targa
1992-2006 Model Technical Specifications
  • A35 Engine
  • 49cc two stroke
  • 38mm X 43mm Bore/Stroke
  • 9.1:1 compression ratio
  • Automatic 2 speed transmission
  • Dellorto SHA 14/12 Carburetor (#53 jet stock)
1992-2006 Model Maintenance Information
  • Gearbox oil: Type A or Type F Automatic transmission fluid.
  • Spark plug: NGK B6HS, Bosch W4A2, Champion L82
  • Spark plug gap: 0.5mm
  • Timing advance: 1.5-0.2mm BTDC
  • Points Gap: 0.35-0.45 mm (Points ignition models only)
Post 2006 Model Technical Specifications
  • A55 Engine
  • 49cc two stroke
  • 10:1 compression ratio
  • Dellorto PHVA 14mm Carburetor 6mm main jet (55) 209 gauge atomizer
  • Fuel: 4l reserve .5l
  • Weight 51kg
  • Wheel Base: 1080mm
  • Overall Length: 1640mm
Post 2006 Model Maintenance Information
  • Gearbox oil: Type A or Type F Automatic transmission fluid. (~300cc)
  • Spark plug: NGK BR8HS
  • Spark plug gap: 0.8mm
  • Chain: 415 HD 93 rollers
  • Sprocket: front 26 tooth rear 28 tooth
  • Shocks: 280mm with 10mm eyes
  • Headlamp: 12v 25w/25w Base: BA20, BA20d, 20mm Double Contact Bayonet
