The following text is from Boyesen:
We have a few reed options available for this reed cage. The reeds we have found are a very close match, however, not a perfect match. Depending upon the width of the reed cage, you may need to slightly sand the sides of the reeds so they will fit properly.
We have a light material dual-stage fiberglass reed set, part # 6108. The price for this reed set is $25.95 USD + shipping.
We offer a heavier material dual-stage fiberglass reed set, for a modified engine, part # 712. The price for this reed set is $25.95 USD + shipping.
We also have a single stage Carbon Tech carbon fiber reed available, part # CT110LT (low tension material) for better low to mid range, or part # CT110HT (high tension material) for top end power use. The price for either Carbon Tech reed set is $32.95 USD + shipping.
All reed sets include 2 reeds, enough for one reed cage.
With best regards,
Cheryl Boyesen Engineering 8 Rhoades Road Lenhartsville, PA 19534 USA tel # 610-756-6818 / 800-441-1177 fax # 610-756-4102 E-mail: info@boyesen.com
"Boyesen Installation Instructions"
"Various Pictures"
