Lets start with what were dealing with here
This pile of random parts is my Puch Maxi. I've had it since 2015 and it has been everything a Puch could be. Cafe racer, scramber, stock looking. I've had it all.
However, one day I bought a leg shield from an old Kreidler and ruined my 72cc Airsal due to lack of airflow.
So thats when I decided to make it watercooled..
Part/spec list:
Engine:
- Puch E50 kickstart casings
- Rito crankshaft
- Surflex clutch
- AF1 Eurokit 43mm cilinder
- Stock AF1 cilinderhead
- Polini 4 Vane reed valve
- Homoet P6
- Dellorto UB22
- PVL ignition
- VDM waterpump
- Rieju MRX radiator
- Custom coolant hardlines
Frame/running gear:
- Fully rigid and lowered oem front forks
- 240mm rear shocks
- Respoked front wheel with Kreidler brake drum
- Respoked rear wheel with conventional bearings
- Kreidler legshield
- Steering bars from child ATV, modified to accept inverted levers
- 1920s bicycle seat
- JAWA headlight
- Battery powered taillight
- OEM Puch cargo rack
-Vintage oil can to hide ignition wiring
And what it used to be:
I'm planning on getting it running this winter and finishing some details on the running gear. If people are intrested, I can dig up some more pictures off the build process so far. Let me know what you think ;)
