Re: Peugeot HPI Timing
Andy f kin Scouten /
> iskra chornia wrote:
> Riggsby turned me on to:
> https://lambretta-images.com/tuningh/port-timing-calculators/degrees-to-mm-timing-calculator/
> . Peugeot has a 39.1mm stroke and 76mm conrod unless you have the 85mm
> conrod malossi "not-stroker but marketed as a stroker cuz euros don't
> know what stroke is apparently" crank in there. From there, get it
> started, and rev out on the stand with the timing light on it, and mark
> where initial fire is and where it ends up retarding down to. You can
> then measure the distance between these with your micrometer and get the
> curve, so you'll know where to set your max advance in order to retard
> down to a reasonable point. I like to set stuff so it retards down to
> 17* or 18* or about 1mm-1.1mm btdc on peugeot, and that makes total
> sense since that's where most people static time le partie, the but
> that's fairly conservative.
Oddly enough I will be using the full Malossi stroker set up on a LC 50cc Doppler cylinder, I think im just gonna try 2.5mm to start then play with the stator position from there to dial it in as I want, I think making marks like you suggested is a good idea, always more to learn!
  Peugeot HPI TimingTopic by: Andy f kin Scouten Andy f kin Scouten 11/07/22 08:24PM
  Re: Peugeot HPI TimingRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/07/22 09:47PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/08/22 07:04AM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 05:23PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/10/22 04:22PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 05:27PM
  Re: Peugeot HPI TimingRe: LSLB RXb LSLB RXb 11/08/22 07:24PM
  Re: Peugeot HPI TimingRe: CORN PED CORN PED 11/08/22 10:06AM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 05:21PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/08/22 07:00PM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 07:56PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/08/22 08:03PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 08:58AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 05:43PM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/10/22 06:20PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/11/22 09:31AM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/12/22 08:25AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/13/22 04:21PM
  Re: Peugeot HPI TimingRe: operator error 696 420 operator error 696 420 11/11/22 01:28AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/19/22 05:46PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/19/22 06:58PM
  Re: Peugeot HPI TimingRe: LSLB RXb LSLB RXb 11/19/22 06:59PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/19/22 11:25PM
