Re: Peugeot HPI Timing
iskra chornia /
Riggsby turned me on to: https://lambretta-images.com/tuningh/port-timing-calculators/degrees-to-mm-timing-calculator/ . Peugeot has a 39.1mm stroke and 76mm conrod unless you have the 85mm conrod malossi "not-stroker but marketed as a stroker cuz euros don't know what stroke is apparently" crank in there. From there, get it started, and rev out on the stand with the timing light on it, and mark where initial fire is and where it ends up retarding down to. You can then measure the distance between these with your micrometer and get the curve, so you'll know where to set your max advance in order to retard down to a reasonable point. I like to set stuff so it retards down to 17* or 18* or about 1mm-1.1mm btdc on peugeot, and that makes total sense since that's where most people static time le partie, the but that's fairly conservative.
  Peugeot HPI TimingTopic by: Andy f kin Scouten Andy f kin Scouten 11/07/22 08:24PM
  Re: Peugeot HPI TimingRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/07/22 09:47PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/08/22 07:04AM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 05:23PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/10/22 04:22PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 05:27PM
  Re: Peugeot HPI TimingRe: LSLB RXb LSLB RXb 11/08/22 07:24PM
  Re: Peugeot HPI TimingRe: CORN PED CORN PED 11/08/22 10:06AM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 05:21PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/08/22 07:00PM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/08/22 07:56PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/08/22 08:03PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 08:58AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/10/22 05:43PM
  Re: Peugeot HPI TimingRe: iskra chornia iskra chornia 11/10/22 06:20PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/11/22 09:31AM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/12/22 08:25AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/13/22 04:21PM
  Re: Peugeot HPI TimingRe: operator error 696 420 operator error 696 420 11/11/22 01:28AM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/19/22 05:46PM
  Re: Peugeot HPI TimingRe: Ryan Nash Ryan Nash 11/19/22 06:58PM
  Re: Peugeot HPI TimingRe: LSLB RXb LSLB RXb 11/19/22 06:59PM
  Re: Peugeot HPI TimingRe: Andy f kin Scouten Andy f kin Scouten 11/19/22 11:25PM
