Re: Thoughts?
Matt Mulligan /
Looking at the map with a clearer head, I remembered the measurements and that i went up 3mm already on the exhaust. Shoulda written them on the map but there was alot of drawing and erasing going on with this boost port idea. Transfers measure 36mm from deck and exhaust is 30.5mm. Exhaust will definitely be left alone until i test it,
No spacer:
Exhaust 144
transfers 106
blowdown 19
intake i don't remember, 102 maybe? it was in the low 100s
boost ports - same as transfers maybe more if i have them open earlier
With 1mm added to the base accounted for:
Exhaust 150
transfers 114
blowdown 18
intake in the 90s with base spacer- to be determined, gonna attack that slowly, probably end up in the 110-120 range, spacer or not.
boost ports - same as above
I feel under 20 degrees of blow down is still in the safe zone especially if those boost ports actually help and i get the pipe dimensions close enough to work with it. Another mm will put me at 158 ex and 22 blow down. I don't know if I can cobble something to support that well enough with stock exhaust parts. Worse case, I have a cool looking paper weight showing me (and everyone reading this) what not to do.
  Thoughts?Topic by: Matt Mulligan Matt Mulligan 05/08/22 07:12PM
  Re: Thoughts?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/08/22 09:06PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/08/22 09:52PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/08/22 10:36PM
  Re: Thoughts?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/08/22 10:41PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/08/22 10:56PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/08/22 10:53PM
  Re: Thoughts?Re: Graham Motzing Graham Motzing 05/08/22 11:54PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 01:37AM
  Re: Thoughts?Re: classic carl jepsen classic carl jepsen 05/09/22 02:41AM
  Re: Thoughts?Re: Graham Motzing Graham Motzing 05/09/22 10:18AM
  Re: Thoughts?Re: classic carl jepsen classic carl jepsen 05/09/22 11:16AM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 11:38AM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 08:11PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 09:14PM
  Re: Thoughts?Re: Graham Motzing Graham Motzing 05/08/22 09:35PM
  Re: Thoughts?Re: classic carl jepsen classic carl jepsen 05/08/22 10:50PM
  Re: Thoughts?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/09/22 09:02PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 09:17PM
  Re: Thoughts?Re: Graham Motzing Graham Motzing 05/09/22 09:26PM
  Re: Thoughts?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/09/22 09:38PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/09/22 10:41PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/09/22 11:14PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/10/22 06:58AM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/10/22 07:44AM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/10/22 12:23PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/10/22 12:30PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/10/22 08:14PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/10/22 09:43PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/12/22 06:21PM
  Re: Thoughts?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/10/22 10:56PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/10/22 11:46PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/08/22 11:01PM
  Re: Thoughts?Re: Graham Motzing Graham Motzing 05/10/22 11:04PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/12/22 06:14PM
  Re: Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 05/12/22 06:52PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/12/22 07:09PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/12/22 08:03PM
  Re: Thoughts?Re: roots to wings roots to wings 05/12/22 10:26PM
  Re: Thoughts?Re: Matt Mulligan Matt Mulligan 05/12/22 10:57PM
