Side bleed estoril
Picked up 2 pipes to try out and yeah estoril is the mopeds moped. Za50 is trying out the 24mm ID stock like and she got a boost coming off a jamarcol with 19mm ID. Also took the 2 treats long seats and cut the foam away and replaced with purple seat cushion.
The series B had a promo circuit pipe when I bought it and last summer was a ripping fun summer. But I think the side bleed estoril is the only pipe I would buy now. I keep starting up Frank just to hear the pipe 😆
Both Frank and Goldie are rebuilt 70cc, Frank got a new crank, Goldie still with stock crank.
Re: Side bleed estoril
Totally normal JBOT /
Side bleed estoril on a treats reed has massive torque for days. I built one up and it was a joy to ride, low clutch stall and climbed the steepest hills at 18/45. Grunty af
Chad Tufts /
I'm thinking about changing gearing, I'm 16/45 now and top speed on flat is 39. Want just a little more speed.
Famous last words . ;)
EH 📣FCC of the QCB /
Your Turing about 8,600 RPMs to get 39 on that gearing. If you pop an 18 front on there and run 18/45 8600 will get you to about 45mph.
Chad Tufts /
That's where I want to be. And I have an 18 and a new chain if I need it. I was looking at the moped toolbox and was gonna try the 17 first but may jump straight to the 18.
classic carl jepsen /
The extra baffle they added is only there to reduce noise this is why older 2 chamber pipes often make more power
Chad Tufts /
I didn't realize the chain cut through the chain guard!! Was cutting into the frame!!
The taller 18t lifts the chain off the frame.
> into the frame!!
You probably went to long on the shocks
You should be doing 50 easy and destroying hills (edited)
Chad Tufts /
> 666 420 wrote:
> > into the frame!!
Hit 46 today with the end bleed closed off. I'll record tomorrow's ride with the end open a bit. I'm only using a stock 15mm bing and metal mesh air filter.
Chad Tufts /
> 666 420 wrote:
> > into the frame!!
No, the shocks are correct. The problem was the chain was too long... gave it too much slack..
Chad Tufts /
> 666 420 wrote:
> > into the frame!!
I bought 340 length shocks, is that too long for a Murray frame? I measured the shocks that came with the bike and bought the same..
Mark Younggren /
What jet your running?
