Re: Changing Timing on Stock CDI - Honda PA50 Hobbit
Chris Temple /
New crank, seals gaskets, entire build.... I have pulled the woodruff key and the plate .. so I am adjusting the plate.. no matter where I put it, the timing light hits the same spot. Have you actually done this with CDI? I know others that have done it with stock points, but not CDI.
What do you not like about the BX?
