Re: Swap SHA for Mikuni?
Dirty30 Dillon /
You don't need to dick around with slides. I run plenty of kitted and piped bikes with SHA's with standard slides and they are fine.
And you can have a carb that has swappable parts, but probably will never tune well for your porting/bore size; or a carb that will function just fine for a stock port map and pipe that requires you to buy some jets.
> Keegan Wilhelm wrote:
> > Dirty30 Dillon wrote:
> > Dellorto makes the SHA, and on a setup like this you don't have to
> muck
> > with slides.
> > You can attempt to put a VM18 on this, but general rule of thumb is
> you
> > want venturi size to be at most 50% of bore. So, on a 38mm~ cylinder
> you
> > wan a ~18mm carb max (and that's theoretical maximum, so including a
> > pipe and porting). Aka, a stock port and intake, and a 12-15mm is more
> > than adequate and youll get better response from the smaller carb.
> with the dellorto comment, i meant a phbg or something similar.
> makes sense with the size, but id rather have more tuneability over
> having to dick around with notching slides and having one jet / emulsion
> tube for the entire rev range. ive got a shit load of mikuni jets, and
> would rather stick to that if I can.
  Swap SHA for Mikuni?Topic by: Keegan Wilhelm Keegan Wilhelm 05/02/22 08:50AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/02/22 09:00AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/02/22 09:09AM
  Re: Swap SHA for Mikuni?Re: Jay Rivett Jay Rivett 05/02/22 10:29AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/02/22 10:41AM
  Re: Swap SHA for Mikuni?Re: Jay Rivett Jay Rivett 05/03/22 10:50AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/03/22 11:10AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/02/22 10:59AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/02/22 11:23AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/02/22 12:10PM
  Re: Swap SHA for Mikuni?Re: Graham Motzing Graham Motzing 05/02/22 12:40PM
  Re: Swap SHA for Mikuni?Re: Born to be WillD Born to be WillD 05/02/22 01:39PM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/02/22 02:26PM
  Re: Swap SHA for Mikuni?Re: P D P D 05/02/22 07:48PM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/03/22 08:14AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/03/22 08:36AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/03/22 08:45AM
  Re: Swap SHA for Mikuni?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/03/22 11:36AM
  Re: Swap SHA for Mikuni?Re: Keegan Wilhelm Keegan Wilhelm 05/03/22 11:41AM
  Re: Swap SHA for Mikuni?Re: Jay Rivett Jay Rivett 05/04/22 12:21AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/04/22 08:15AM
  Re: Swap SHA for Mikuni?Re: Graham Motzing Graham Motzing 05/04/22 02:39PM
  Re: Swap SHA for Mikuni?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/04/22 03:46PM
  Re: Swap SHA for Mikuni?Re: Jay Rivett Jay Rivett 05/05/22 10:29AM
  Re: Swap SHA for Mikuni?Re: Dirty30 Dillon Dirty30 Dillon 05/05/22 10:53AM
  Re: Swap SHA for Mikuni?Re: Graham Motzing Graham Motzing 05/05/22 02:01PM
  Re: Swap SHA for Mikuni?Re: Jay Rivett Jay Rivett 05/06/22 10:53AM
  Re: Swap SHA for Mikuni?Re: Born to be WillD Born to be WillD 05/03/22 11:44AM
  Re: Swap SHA for Mikuni?Re: Eric Davenport Eric Davenport 05/03/22 03:27PM
