> Dirty30 Dillon wrote:
> Dellorto makes the SHA, and on a setup like this you don't have to muck
> with slides.
> You can attempt to put a VM18 on this, but general rule of thumb is you
> want venturi size to be at most 50% of bore. So, on a 38mm~ cylinder you
> wan a ~18mm carb max (and that's theoretical maximum, so including a
> pipe and porting). Aka, a stock port and intake, and a 12-15mm is more
> than adequate and youll get better response from the smaller carb.
with the dellorto comment, i meant a phbg or something similar.
makes sense with the size, but id rather have more tuneability over having to dick around with notching slides and having one jet / emulsion tube for the entire rev range. ive got a shit load of mikuni jets, and would rather stick to that if I can.
