You don't need to dick around with slides. I run plenty of kitted and piped bikes with SHA's with standard slides and they are fine.
And you can have a carb that has swappable parts, but probably will never tune well for your porting/bore size; or a carb that will function just fine for a stock port map and pipe that requires you to buy some jets.
> Keegan Wilhelm wrote:
> > Dirty30 Dillon wrote:
> > Dellorto makes the SHA, and on a setup like this you don't have to
> muck
> > with slides.
> > You can attempt to put a VM18 on this, but general rule of thumb is
> you
> > want venturi size to be at most 50% of bore. So, on a 38mm~ cylinder
> you
> > wan a ~18mm carb max (and that's theoretical maximum, so including a
> > pipe and porting). Aka, a stock port and intake, and a 12-15mm is more
> > than adequate and youll get better response from the smaller carb.
> with the dellorto comment, i meant a phbg or something similar.
> makes sense with the size, but id rather have more tuneability over
> having to dick around with notching slides and having one jet / emulsion
> tube for the entire rev range. ive got a shit load of mikuni jets, and
> would rather stick to that if I can.
