Re: Batavus hs 50, Morini Cylinder ???
Dirty30 Dillon /
> Gary Flowers wrote:
> > Nick MBC wrote:
> > I'm making more spacers to bolt on M1 cylinders to M48s sometime in
> the
> > next year. You will need to bore your cases though
> I have a small machine shop and I would like to make one myself, Can you
> share the thickness of the spacer needed for the M1 cylinders, Also have
> you guys looked at the European cylinder kits for the Morini AC and LC
> type scooter engines as a viable option for M48 engines?
They're not really a viable option, and even if you could bolt them onto the motor, you have the most maligned clutch system amongst all mopeds.
But than again, if you have a machine shop, you can theoretically make whatever you want work.
