Re: QT50 and SHA slide tuning
Graham Motzing /
Well, for starters, the exact idle rpm would be a function of the carb choice to a certain degree, don't sweat that, set the idle high enough that it won't die and low enough that it won't grab the clutch.
As far as the slides go, you already have them so try them and see. Inside the carb there is a emulsion tube that runs vertical with holes in it, the different slide shapes are trying to reduce vacuum (increase pressure) on that tube by slowing down the air velocity at 0-30% throttle give or take. Reducing the vacuum causes less fuel to flow.
Based on your temps it sounds like you're already tuned pretty well, at low load the temp will definitely drop. Head Temp isn't really a good tuning tool the way you're talking about it here, it's only a warning light duty something being way wrong.
  QT50 and SHA slide tuningTopic by: Real first name Real last name Real first name Real last name 04/24/22 01:53AM
  Re: QT50 and SHA slide tuningRe: Graham Motzing Graham Motzing 04/24/22 07:40AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/24/22 10:12AM
  Re: QT50 and SHA slide tuningRe: Dirty30 Dillon Dirty30 Dillon 04/24/22 10:47AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/24/22 12:39PM
  Re: QT50 and SHA slide tuningRe: LSLB RXb LSLB RXb 04/24/22 01:38PM
  Re: QT50 and SHA slide tuningRe: Tom Boyd Tom Boyd 04/24/22 03:12PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 11:10AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 12:15AM
  Re: QT50 and SHA slide tuningRe: Jack Rutherford Jack Rutherford 04/24/22 11:22PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 12:29AM
  Re: QT50 and SHA slide tuningRe: LSLB RXb LSLB RXb 04/25/22 06:49AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 12:19PM
  Re: QT50 and SHA slide tuningRe: Jack Rutherford Jack Rutherford 04/24/22 09:07AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/24/22 10:00AM
  Re: QT50 and SHA slide tuningRe: Jack Rutherford Jack Rutherford 04/24/22 10:35AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/24/22 11:52AM
  Re: QT50 and SHA slide tuningRe: pat splat pat splat 04/24/22 12:17PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/24/22 12:49PM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/25/22 10:31AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 11:02AM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/26/22 10:36AM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/26/22 10:40AM
  Re: QT50 and SHA slide tuningRe: Tom Boyd Tom Boyd 04/26/22 04:27PM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/27/22 10:14AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/27/22 11:23AM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/28/22 10:08AM
  Re: QT50 and SHA slide tuningRe: Graham Motzing Graham Motzing 04/25/22 11:17AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 12:48PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 01:22PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 03:27PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 04:24PM
  Re: QT50 and SHA slide tuningRe: Tom Boyd Tom Boyd 04/25/22 05:23PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/25/22 06:01PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/27/22 11:38AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/27/22 11:23PM
  Re: QT50 and SHA slide tuningRe: LSLB RXb LSLB RXb 04/27/22 11:31PM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/28/22 12:06AM
  Re: QT50 and SHA slide tuningRe: LSLB RXb LSLB RXb 04/28/22 07:08AM
  Re: QT50 and SHA slide tuningRe: Real first name Real last name Real first name Real last name 04/30/22 10:27AM
  Re: QT50 and SHA slide tuningRe: Jay Rivett Jay Rivett 04/30/22 12:24PM
