1 simple trick to improve stock Puch Maxi forks
CORN PED /
This is so simple. . . but makes an incredible difference.
Pull out your stock puch maxi fork lowers. Just unbolt them and pull em out.
CLEAN THEM.
Then unscrew the upper spring and cut off the excess upper tube above the slider.
Then screw the spring back in, grease em up, and put them back together.
This increases your travel just enough to make them ride so much better than stock.
Its just so stupid that it works.
  1 simple trick to improve stock Puch Maxi forksTopic by: CORN PED CORN PED 04/20/22 04:14PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 04/20/22 05:08PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/20/22 05:48PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 04/20/22 07:24PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Cincy Kid Cincy Kid 04/20/22 06:45PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: campeona del mundo campeona del mundo 04/20/22 07:56PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/20/22 11:15PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 04/21/22 09:08AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Cincy Kid Cincy Kid 04/20/22 11:24PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Born to be WillD Born to be WillD 04/21/22 11:50AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: roots to wings roots to wings 04/21/22 12:25PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/23/22 03:02PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/23/22 03:11PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/23/22 04:14PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 04/23/22 05:02PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: CORN PED CORN PED 04/23/22 05:57PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/23/22 06:19PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: roots to wings roots to wings 04/23/22 09:50PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Sean Hennessey Sean Hennessey 04/23/22 11:09PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Garrett The Kid Garrett The Kid 04/24/22 02:21AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 04/24/22 07:26AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: CORN PED CORN PED 04/24/22 05:07PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/24/22 05:50PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Totally normal JBOT Totally normal JBOT 04/24/22 12:23PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Jesse Stephenson Jesse Stephenson 04/23/22 05:05PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/23/22 05:07PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: ✝️TD-THE MORAL AUTHORITY✝️ ✨ ✝️TD-THE MORAL AUTHORITY✝️ ✨ 04/24/22 08:53AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 04/24/22 11:39AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: roots to wings roots to wings 05/11/22 09:15AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Dirty30 Dillon Dirty30 Dillon 05/11/22 09:16AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: roots to wings roots to wings 05/11/22 10:55AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 05/11/22 12:37PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: roots to wings roots to wings 05/11/22 01:07PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: Graham Motzing Graham Motzing 05/11/22 02:24PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 05/11/22 03:42PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: CORN PED CORN PED 05/12/22 10:56AM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: LSLB RXb LSLB RXb 05/12/22 12:39PM
  Re: 1 simple trick to improve stock Puch Maxi forksRe: ✝️TD-THE MORAL AUTHORITY✝️ ✨ ✝️TD-THE MORAL AUTHORITY✝️ ✨ 05/13/22 09:42AM
