> Dirty30 Dillon wrote:
> Fairly certain Johnny's TTLX is just the factory black sheathing, it's
> nothing hard.
> In fact, I can't think of an instance where I would ever want conduit on
> a bike. Far better to have a pliable rubber/plastic sheathing like
> factory and retain that with the factory cover that goes under there or
> even just some neatly tucked zipties.
> In order to run conduit, you'd have to consider that any terminations
> you make in the ends are going to have to be redone any time you want to
> disassemble, and/or change layout. Then there is obvious jacket chaffing
> which needs to be addressed with strain relief, etc.
> As far as Jake's build, I would consider that a master class on
> wire/cable management. And if he has a particular method for getting
> around chaffing and connectorizing, you'd have to hit him up and ask.
> It's far easier just to buy the factory part and be spend the
> effort/time/resources on a more rewarding part of the build
this part states its for 07-08 LX and ST would that work for my 99 because this is exactly what i want. When I google "Tomos Targa lx" I don't find this part on any moped, all of them wither have zip ties like here, or its hanging down looking tattered and faded.
> Graham Motzing wrote:
> That tubing is really hard to come by, it's cheap cheap in 600' rolls but everyone
> selling small chunks marks it up like crazy
> https://www.walmart.com/ip/BLACK-PVC-Sleeve-Wiring-Harness-Loom-FLEXABLE-
> Wire-Cover-TUBE-CORD-PROTECT-LOT-Diameter-for-1-4-1-2-3-4-Size-nbsp-
> Choose-nbsp/456840121
The black tube is something Id like to use either by itself, or under the cover that Dirty30 Dillon wrote about.
one more thing, "As far as Jake's build, I would consider that a master class on
> wire/cable management."
^Im not sure if that's an expression, or a statement. I would not consider taking any classes for this. Im sure If I had a tube that was big enough for the wires, and covered the wires in that black plastic tube, then copped the ends to allow for movement, and added a rubber seal/edge to it That would be fine, I was just trying to find out if something was already available in the community.
