Getting to see those bikes up close like that is awesome. Thanks for the share!
Awesome recap vid, good to see your bike early on.
Now im a noob but i seemed to notice a few people running the same cylinder head as you, except rotated 180 degrees. I notice it
has a wierd asymetric cast on the front, any benefit to either orientation or no difference?
Those cylinder heads are from Kreidler, same stud spacing as a normal puch(43x43mm), and other versions available with wide stud spacing like mine(58x58mm)
theoretically mine is placed wrong, the exhaust port side of the cilinder is the hottest part of the cylinder, so you would want the most cooling there.
But you wont even feel a difference placing the head upside down
Yeah the slight increase in exhaust side cooling came to mind. Also potebtially feont tire clearance under full fork compression
Excellent work!
