Re: Moby polini av10 build having issues
Daniel '' /
What helps the rubber not rip is setting the correct preload on the engine bolt. You know, just because you have built a bunch of bikes doesn’t mean you know what you’re doing. I have worked on thousands of mopeds and still learn new stuff every day.
Not saying I’m above sketchy fixes, but with mobys, especially tuned ones, you have to dampen all the vibrations. Like even using silent blocks to make a support for the spigot carb mount to mount to the case and rubber hose to mellow the spring rattle, don’t forget to lock wire every nut too! Otherwise you end up with a buzzy-rattle trap that’s main purposes is ejecting hardware and foaming fuel. (edited)
  Moby polini av10 build having issuesTopic by: Conan shifty smo G Conan shifty smo G 03/26/22 02:28PM
  Re: Moby polini av10 build having issuesRe: Totally normal JBOT Totally normal JBOT 03/26/22 03:07PM
  Re: Moby polini av10 build having issuesRe: Conan shifty smo G Conan shifty smo G 03/26/22 03:19PM
  Re: Moby polini av10 build having issuesRe: Totally normal JBOT Totally normal JBOT 03/26/22 04:01PM
  Re: Moby polini av10 build having issuesRe: Mike Boyd Mike Boyd 03/26/22 05:39PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 01:10PM
  Re: Moby polini av10 build having issuesRe: Graham Motzing Graham Motzing 03/28/22 01:20PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 01:35PM
  Re: Moby polini av10 build having issuesRe: Nick / Ratbone Nick / Ratbone 03/27/22 08:39PM
  Re: Moby polini av10 build having issuesRe: Dirty30 Dillon Dirty30 Dillon 03/27/22 08:42PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 03/28/22 06:21PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 07:54PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 04/09/22 03:32PM
  Re: Moby polini av10 build having issuesRe: 666 420 666 420 04/09/22 06:47PM
  Re: Moby polini av10 build having issuesRe: Drew Thomas Drew Thomas 04/26/22 02:25PM
  Re: Moby polini av10 build having issuesRe: Conan shifty smo G Conan shifty smo G 04/26/22 08:30PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 04/27/22 10:08AM
  Re: Moby polini av10 build having issuesRe: Graham Motzing Graham Motzing 04/27/22 12:43PM
  Re: Moby polini av10 build having issuesRe: todd amundson todd amundson 04/28/22 11:59AM
