> Graham Motzing wrote:
> What's up with the motor mounts? Is it a washer with a conventional
> rubber mount or did you do some kind of custom aluminum hard mount
> thing?
> Motor mount issues can make the foaming really bad. Usually spigot
> mount carb it's not a problem so much, but who knows. Every kit, crank,
> variator, intake is going to have a different vibration.
He has a washer over the rubber bushing, I do this sometimes as well, it gives the rubber less area to rip away on big vibrating kits
