Moby polini av10 build having issues
Conan shifty smo G /
Reaching out for maybe a dumb tip to help get my bike right. This is my first french build to this extent. The issue I'm having repeatedly is I can get about 1/4 mile down the road about 0-53 mph then I'll fuel starve regardless of float height, gas cap on or off and jetting.
My set up is polini av10 race cases
Factory 4 petal
21 phbg matched intake
Artek crank
Parmakit 74cc air cooled
Gianelli 97mm pipe
Ere clutch less variator
Ere clutch less pulley
Le parti at 1.1 btdc
Red engine spring
With an inline on off 1/4" fuel shut off
Fuel is flowing, I have no air leaks, everything on the build is fresh, I've tried 3 different carbs, 2 complete different ignition set ups new out of box, different plug boots, different coil wires, played with float heights, played with jetting and filters as well as no filter. Is a fuel pump something I should try? Any other recs i should try? I'm just tryna rip this bike. Any tips are appreciated.
  Moby polini av10 build having issuesTopic by: Conan shifty smo G Conan shifty smo G 03/26/22 02:28PM
  Re: Moby polini av10 build having issuesRe: Totally normal JBOT Totally normal JBOT 03/26/22 03:07PM
  Re: Moby polini av10 build having issuesRe: Conan shifty smo G Conan shifty smo G 03/26/22 03:19PM
  Re: Moby polini av10 build having issuesRe: Totally normal JBOT Totally normal JBOT 03/26/22 04:01PM
  Re: Moby polini av10 build having issuesRe: Mike Boyd Mike Boyd 03/26/22 05:39PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 01:10PM
  Re: Moby polini av10 build having issuesRe: Graham Motzing Graham Motzing 03/28/22 01:20PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 01:35PM
  Re: Moby polini av10 build having issuesRe: Nick / Ratbone Nick / Ratbone 03/27/22 08:39PM
  Re: Moby polini av10 build having issuesRe: Dirty30 Dillon Dirty30 Dillon 03/27/22 08:42PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 03/28/22 06:21PM
  Re: Moby polini av10 build having issuesRe: Toledo Riot Toledo Riot 03/28/22 07:54PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 04/09/22 03:32PM
  Re: Moby polini av10 build having issuesRe: 666 420 666 420 04/09/22 06:47PM
  Re: Moby polini av10 build having issuesRe: Drew Thomas Drew Thomas 04/26/22 02:25PM
  Re: Moby polini av10 build having issuesRe: Conan shifty smo G Conan shifty smo G 04/26/22 08:30PM
  Re: Moby polini av10 build having issuesRe: Daniel '' Daniel '' 04/27/22 10:08AM
  Re: Moby polini av10 build having issuesRe: Graham Motzing Graham Motzing 04/27/22 12:43PM
  Re: Moby polini av10 build having issuesRe: todd amundson todd amundson 04/28/22 11:59AM
