Re: The least sketchy way to do this sealed bearing conversion
* wormdirt * /
> P D wrote:
> > 🇮🇹💦 Of the Loin wrote:
> > They are 361201 though
> > Slight difference in numbers ;)
> Hmm , why would the seal have 6201 ? Maybe uses the same seal as ...
> just the inside bore is different .
> True the 361201 measures :
> 35 mm Outside diameter
> 12 mm Bore diameter
> 10 mm Width
Ok so the 361201 from SKF is a viable replacement. Hmm maybe my boys at the shop we're trying to keep the 11mm width in there as a factor. Totally irrelevant for wheel bearing swaps though.
  The least sketchy way to do this sealed bearing conversionTopic by: * wormdirt * * wormdirt * 03/16/22 04:59PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 05:10PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 05:22PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 05:23PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 05:54PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Graham Motzing Graham Motzing 03/16/22 05:38PM
  Re: The least sketchy way to do this sealed bearing conversionRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/16/22 06:05PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 06:34PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:08PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 07:47PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Full Tuck Full Tuck 03/16/22 07:21PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:23PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/16/22 07:37PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:49PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 07:55PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/16/22 08:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 09:54PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 09:58PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/16/22 10:58PM
  Re: The least sketchy way to do this sealed bearing conversionRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/16/22 11:10PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 02:33PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 06:04PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 06:27PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 07:02PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/17/22 07:11PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 10:02PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/18/22 10:18AM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/18/22 11:07AM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/18/22 11:36AM
  Re: The least sketchy way to do this sealed bearing conversionRe: CORN PED CORN PED 03/18/22 11:46AM
  Re: The least sketchy way to do this sealed bearing conversionRe: CORN PED CORN PED 03/17/22 10:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/17/22 01:03AM
  Re: The least sketchy way to do this sealed bearing conversionRe: Full Tuck Full Tuck 03/17/22 09:03AM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 11:30AM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/17/22 02:05PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/18/22 12:17AM
  Re: The least sketchy way to do this sealed bearing conversionRe: Garrett The Kid Garrett The Kid 03/18/22 01:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Michael Gamba Michael Gamba 04/29/22 02:11PM
