The least sketchy way to do this sealed bearing conversion
* wormdirt * /
This damn Sachs snowflake has a needs a 12mm x 35mm bearing. Apparently those don't exist.
I can..
A: use ye olde 6201 12mm x 32mm and shim the 3mm. Green locktite. Bam. The bearing would still hit the lip on the inside of the hub + ya know spacer in the middle and all that.
B: use the 6202 15mm x 35mm and shim the axle.
Both methods are doable but both seem equally shitty.
  The least sketchy way to do this sealed bearing conversionTopic by: * wormdirt * * wormdirt * 03/16/22 04:59PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 05:10PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 05:22PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 05:23PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 05:54PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Graham Motzing Graham Motzing 03/16/22 05:38PM
  Re: The least sketchy way to do this sealed bearing conversionRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/16/22 06:05PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 06:34PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:08PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 07:47PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Full Tuck Full Tuck 03/16/22 07:21PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:23PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/16/22 07:37PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 07:49PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/16/22 07:55PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/16/22 08:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 09:54PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/16/22 09:58PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/16/22 10:58PM
  Re: The least sketchy way to do this sealed bearing conversionRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/16/22 11:10PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 02:33PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 06:04PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 06:27PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 07:02PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/17/22 07:11PM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/17/22 10:02PM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/18/22 10:18AM
  Re: The least sketchy way to do this sealed bearing conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/18/22 11:07AM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/18/22 11:36AM
  Re: The least sketchy way to do this sealed bearing conversionRe: CORN PED CORN PED 03/18/22 11:46AM
  Re: The least sketchy way to do this sealed bearing conversionRe: CORN PED CORN PED 03/17/22 10:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Mike Boyd Mike Boyd 03/17/22 01:03AM
  Re: The least sketchy way to do this sealed bearing conversionRe: Full Tuck Full Tuck 03/17/22 09:03AM
  Re: The least sketchy way to do this sealed bearing conversionRe: P D P D 03/17/22 11:30AM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/17/22 02:05PM
  Re: The least sketchy way to do this sealed bearing conversionRe: * wormdirt * * wormdirt * 03/18/22 12:17AM
  Re: The least sketchy way to do this sealed bearing conversionRe: Garrett The Kid Garrett The Kid 03/18/22 01:56PM
  Re: The least sketchy way to do this sealed bearing conversionRe: Michael Gamba Michael Gamba 04/29/22 02:11PM
