50/50 club
Gotta dumb question, can I join the 50/50 club using a 50cc kit OR is it stock modified cylinders only? Asking for a friend........
Re: 50/50 club
Blake Totally a real doctor /
I've always understood it as any 50cc kit. It is more impressive with a ported stock cylinder though. A 50/50 stock cylinder e50 is more impressive than a Polini av10 but I think both technically count.
Re: 50/50 club
I think you can claim 50/50 for a kit, still isn't easy. A 50cc av-10 with cases and the whole works is pretty challenging to build and tune.
Re: 50/50 club
Garelli Master✨ /
Im thinking Puch
Re: 50/50 club
I took the easy route to 50/50 town...
Re: 50/50 club
It's as hard as you wanna make it!
Re: 50/50 club
I am hoping to port a stock tomos cyl for this...
Re: 50/50 club
EH 📣FCC of the QCB /
Stock A55 Cylinder: Easy Route
Stock Puch 1hp Cylinder: Hard route
Re: 50/50 club
Garelli Master✨ /
And you know I'll take the hard route!
Re: 50/50 club
You know it dude!
Re: 50/50 club
steel sleeve restricted puch cylinder is very hard mode.
Re: 50/50 club
And keep it PP for exxxtra hard
Re: 50/50 club
Garelli Master✨ /
I'm definitely keeping it piston port for a little extra fun!
Re: 50/50 club
Garelli Master✨ /
Do It!
Re: 50/50 club
Re: 50/50 club
Garelli Master✨ /
Which one is that?
Re: 50/50 club
The 1hp. Post your trials for records sake
Re: 50/50 club
> Which one is that?
The one I was talking to you about today. The open transfer one. Some states or all the kits idk 🤷🏼‍♂️ had a 8mm bushing pressed in the intake. The one I did I heated it up and knocked it out with a punch. Kit has lots of potential.
Re: 50/50 club
I gotta an a35 cyl, not the cheater a55. Ha!
I have it started already just need to make some time to finish it up.
Re: 50/50 club
Nice thing about the a35 is that you can go huge on the ports without losing all your bottom end.
Bad thing is the transfers suck and it's hard cast iron.
The 38mm alukit is a nice middle ground, technically it's a kit but it's really just a aluminum stock cylinder the way it's ported.
Re: 50/50 club
^^^ Truth. I have done several for people since I don’t own one. I have one at my house that I am holding fro a friend…..I may make it just just because 🤷🏼‍♂️ Have a pipe and everything for it. Hummmm
I use the round dremil metal cutting bit and it works awesome! Zips through it. I ruined a set of bits that I use for aluminum, mainly because the cast is so hard. Bent a bit and it reeked all kinds of Havoc in a port.
Re: 50/50 club
This is the route I took on my Maxi, though I used the Airsal version, I built this bike for a Zeros 50/50 group winter build-off
54 on 50
Link to the Garage page
I have since added a ported 64cc Tomos Airsal to replace the 50 kit, now it does 55 but has much better pull then the 50 kit, but truth be told it was cooler with the 50
Re: 50/50 club
Garelli Master✨ /
Anyone wants to play mopeds? Only rule is E50 cases and and factory 38mm (hero doesn't count 😅) puch cylinder OR factory 38mm A35 cylinder. Sky is the limit with anything else! What ya say?!? Get in here!
Re: 50/50 club
operator error 696 420 /
Definitely! The streetmate stock piston port cylinder makes 4hp I believe?
I have an extra a52 streetmate cylinder if your interested. The transfers are massive on the cylinder!
Re: 50/50 club
Garelli Master✨ /
> believe?
I actually have a good top end I took off my streetmate but there is no fun in that! I have to be different and do it the hard way.
Re: 50/50 club
Why can't I do a hero cyl?
Re: 50/50 club
Garelli Master✨ /
Not the 43.5 cylinder. If you have a 38 it's fair game.
Re: 50/50 club
Garelli Master✨ /
Hell I'll even allow a a35 with a35 cylinder if it gets more people to play.......
Re: 50/50 club
I have a 50cc hero cyl as well as the 65cc one. I feel like my 50cc is the 38mm version.
I am also building the a35 cyl for a tomos.
Re: 50/50 club
Garelli Master✨ /
> the 38mm version.
Do I smell a challenge?!? 🤔
