Did they actually sell out? They didn't move for months and I wasn't planning on making any more.
If there is demand I'll run them again.
Hmm looks like they are still in stock?
Dos also got in the s6 streetrace cylinder for only 144$ holy schnackers blow the doors off just about any damn thing in the world of mopeds.
What piston would you use that that? Stock v1 is like 38.8mm, the one that comes with that kit is a 10 pin, and V1s have a 12 pin crank...
But hey, 52.8ccs of awesomeness!
> schnackers
Almost all minarelli H scooter parts have a 12 pin piston available with the same stroke and spacing so I would probably look for an equivalent piston made for that version of a H kit. That's what I did with the 70.
<3, The trick metric is holding great on my mallossi but this polini is ported a little more aggressive in comparison.
Interesting. I'm not finding a 12 pin version of that kit, but it seems like this might work? Vertical minarelli on a Yamaha, 40mm diameter piston, 12 pin.
Edit: Oooooooh, V vs H, gotcha.
So like this: https://www.maxiscoot.com/en/product/piston-stage6-streetrace-50cc-d.40mm-pin-12mm-80798 (edited)
I’ve been looking around and there is a few kits that come with a 12mm wrist pin already just so you aren’t having to buy the kit and a new piston right off the bat
Treats had the Athena 47.6mm 12 pin 43mm stroke kit pop up on the website so I had to jump on it .
https://www.treatland.tv/athena-minarelli-vertical-70cc-47-6mm-cylinder-kit-p/athena-074700-1.htm
The spacer is on the way so I can start mocking up soon
Here’s some pics of it
