Pinasco Dual Carb/Reed Valve side intake case half assembly
So I’m a Noob when it comes to reed valves, but I would like to learn more about them.
I bought this case half for a future build: vespa pinasco dual carb reed valve case half for stock to 43mm cylinders
and I’m curious who has built one of these and primarily how the heck the reeds attach.I know typical reeds sit inside a reed block but these seem oddly different than most typical reeds (which is why I didn’t think it came with the reeds initially).
I know I need a specific crank or to modify and existing crank, I’m just trying to get an idea of assembly beyond the basic instructions.
Re: Pinasco Dual Carb/Reed Valve side intake case half assembly
Check out this thread if you haven’t seen it yet.
https://www.mopedarmy.com/forums/read.php?7,4432357,page=1
