Re: Garelli NOI gearing
Garelli Master✨ /
> Eugene Robertson wrote:
> I’ve had an 80’ SSXL 25mph model for awhile that I’ve thrown a
> tric-matic 70cc kit, a polini performance pipe, and moved a 16sha over
> to it! Still really dragging on the acceleration. I’m in NYC and rarely
> face any serious hills. Just need oomph off the line. About to rebuild
> the bottom end, so wondering about gearing. It’s stock 10x36 now. Should
> I go big like 46T on the rear? 11 on the front? A mix? Need some takes.
> Thanks doggies!
With that setup you should be a rocket to 36-38mph. What is your timing set at? The woodruff key could have slipped a little OR like mentioned before your clutch rubber is swollen. How does it idle when you come to a stop? Can you put it on the stand and with it idling stop the rear tire and it doesn't cut off or try to cut off? Also is it hard to start or does it start up easily?
