> Dirty30 Dillon wrote:
> If you aren't hauling with all that gear, its not the gearing holding
> you back.
I agree with this, while Garelli’s are not torque monsters (with the stock clutch), mine are still quick off the line, I recommend the stock 30mph gearing, sometimes I like to switch the front from a 10 to an 11.
Your stock clutch is likely swollen, remove it and replace it, or take it out and soak it in mineral spirits. It can also be shaved down a bit which helps the bottom end some, paring the new clutch with a smaller pipe or a circuit also helps, the NOI has a short stroke so huge chambers are gonna cost ya big time down low
