My swinging hobbit engine on pinto frame with moby pulley needed more travel, the original mini scooter spring / shock bottomed out too quickly. Wasn’t a problem with my crazy high revving kit I used to run, but since I threw on a DR, it’s just topping out way too fast.
So I added a recut Xtreme bell at 11deg, and my vari is at 10 deg, identical to the malossi variotop. That will allow big variation.
Then I needed to make a springy assembly, took forever cuz I thought I wouldnt have room to run the scooter contra I was running before, but when I was almost done I saw a perfect spot for it inside the old pinto frame. And holes that existed in the frame fit it like it was meant to go there.
I ran a shock eye from a hobbit shock I think.... attached to the lowest motor mount on the hobbit engine. The eye is threaded, so I just added a threaded rod (an engine stud I found).
Then I took the nylon inner piece from a revival shock and turned it to fit into some pipe, welded nuts onto each side with holes in the pipe so the bolts could go thru the assembly as the pivot points.
Then I cut a groove to hold the scooter contra in the nylon, and had to play with spacing to avoid hitting the intake but finally it came together.
Now I just have to change the pipe mount to attempt to keep the swing angle closer to the engine swing angle....those mid pipe ball joints prefer to not move a ton so if I can match the angle it might not have to move much in its swing. Not ready for parallelogram just yet.
Anyways, psyched on this.
