Hi there!
What exhaust is perfect for 45mm Athena small reedvalve and 21 Dellorto. Is for a Maxi Z50. Would a Homoet P6 pipe be the shizzle?* Moved to this forum by grahammotzing
Hi there!
My z50 clutch even with the thicker metra kit spring would want to slip and Needed to slip to get In to the powerband and then pads would glaze over when using a pipe with no low end like a 6p
From your other posts you’re hell bent on getting a 6p pipe so just do it
Haha, yeah my experience with the 2 speed manual Sachs was that the peakier the power the more it blows though the clutch. Never built a z50 puch motor but I'd stick to something like an estoril with a flatter power band.
> power band.
I was gonna suggest and Estoril, because Estoril
I had that kit on an E50 years ago and ran it with an MLM Cali pipe. They paired nicely together. Great acceleration and top speed. Used both 19 and 21 PHGB and both performed well.
