Re: Peugeot belt length: Malossi Multivar
Toledo Riot /
BUMP
So here is an amalgamation of info gleamed from a few sources/ trial and error
reference this thread from Mars in which he finds the proper belt for the Multivar
and further this thread which has some more belt info
But hers the long and the short
for the Malossi multivar you want to run this belt as it has a deeper V that fits the cheek angles of the variator
you can also run a Gates BX32 belt as it will match one cheek of the variator perfectly, not so great on the other, it will work, but it will break down qucikly
If you are insistent on an AX belt, aka you wanna do wheelies, you need the Gates AX31 as the inner diameter of the variator is smaller then stock resulting in the need for a 31 not a 32
This is JUST for the Multivar, not the ER2/ER3, those work best with a good old Gates AX32 or the special toothed Malossi belt (I still prefer the Gates)
  Peugeot belt length: Malossi MultivarTopic by: Toledo Riot Toledo Riot 12/02/21 09:18AM
  Re: Peugeot belt length: Malossi MultivarRe: Beach Club Nick Beach Club Nick 12/02/21 01:27PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 12/02/21 02:59PM
  Re: Peugeot belt length: Malossi MultivarRe: Beach Club Nick Beach Club Nick 12/02/21 03:45PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 12/02/21 04:14PM
  Re: Peugeot belt length: Malossi MultivarRe: LSLB RXb LSLB RXb 12/02/21 03:42PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 12/02/21 04:13PM
  Re: Peugeot belt length: Malossi MultivarRe: jumpsuit steve jumpsuit steve 12/03/21 11:56AM
  Re: Peugeot belt length: Malossi MultivarRe: LSLB RXb LSLB RXb 12/03/21 12:50PM
  Re: Peugeot belt length: Malossi MultivarRe: b to the eff b to the eff 12/03/21 01:11PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 12/03/21 02:35PM
  Re: Peugeot belt length: Malossi MultivarRe: jumpsuit steve jumpsuit steve 12/03/21 05:05PM
  Re: Peugeot belt length: Malossi MultivarRe: LSLB RXb LSLB RXb 12/03/21 06:20PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 12/03/21 02:13PM
  Re: Peugeot belt length: Malossi MultivarRe: b to the eff b to the eff 12/03/21 06:07PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 05/06/22 12:27PM
  Re: Peugeot belt length: Malossi MultivarRe: Graham Motzing Graham Motzing 05/06/22 01:05PM
  Re: Peugeot belt length: Malossi MultivarRe: L e e L e e 05/06/22 01:32PM
  Re: Peugeot belt length: Malossi MultivarRe: Toledo Riot Toledo Riot 05/06/22 02:18PM
