> b to the eff wrote:
> > LSLB RXb wrote:
> > > piston position difference @ 18.5 deg is 1.302mm - 1.271mm = .031
> mm
> > > aka .0012"
> > still makes a difference :)
> While you could measure the difference, I think this is well below the
> accuracy with which any of us can place a flywheel on a crank. Unless
> there's some super secret trick I'm not aware of. :-)
with French bikes the stator is not movable, but if you are running say a Pietcard you would set the flywheel then move the stator plate for the fine fine adjustments, but I still agree, accuracy to that extent is beyond most of us, myself included
