Re: Don’t need fancy clutches
Probably Fred /
Stock puch clutches are amazing, There is so much you can do with them, because of asbestos linings they last a long time and if you use synthetic motor oil instead of junk type f linings last even longer, slip a bit better, have less fade when hot as well as more protection for bearings and gears too.
I’ve been using regular and Synthetic motor oil in different weights instead of type f fluid in my stock modded and kitted Za50’s and e50s and some other brands of mopeds for 20 years and clutch, tranny wear is almost non existent
