Shitty Reeds on a Shitty moby
First Name Last Name /
I’ve been thinking about purchasing these questionable reeds meant for a motorized bicycle and putting it on an AV7. Now I swear I’ve seen pics of these being used on AV7s on here before but I can’t seem to find them no’mo. Now I know I gotta port the cylinder and case for the reeds but Has anyone used these reeds before? How was it? Is it worth it? Thank you guys.
Re: Shitty Reeds on a Shitty moby
Eric Davenport /
Moby stud spacing is much wider than that adapter.
Eric Davenport /
Also the reeds are shit
Totally normal JBOT /
It looks close to fitting the av7 intake.
I did that with a Goped reed. Just have to make it work. Chop fins, etc
todd amundson /
That’s the second generation of the 90• Dio bicycle block. It has a plastic cage with dio size reeds. The reeds sit in the block 90 degrees off from a dio setup. You can upgrade the pedals with a number of options. I use the first generation of the block you show on a Ciao. The reeds generally come in stainless from the factory.
How’s the performance on that? You run into any major problems?
