Re: Grande carb upgrade
b to the eff /
> Kevin Bishop wrote:
> Not sure what’s in the gear box,it’s stock. It could use a going over
> too.
There are several stock configurations, and several choices for aftermarket ones. These wiki articles are helpful:
https://www.mopedarmy.com/wiki/Vespa_and_Kinetic_Transmissions
https://www.mopedarmy.com/wiki/Calculating_your_Vespa_rear_gearbox_ratio
> What happened to someone making aluminum rollers for stock variators?
No longer available, but you can get the same weight by choosing the 2.8g option here:
https://www.treatland.tv/vespa-piaggio-14mm-x-14mm-weights-pick-a-weight-p/vespa-14x14-weights.htm (edited)
