Re: Powerdynamo wiring
Dirty30 Dillon /
^^^ Brian's advice is what you need.
The Powerdynamo you bought has VDC output, so you'll want everything in parallel and everything with a good solid ground.
You should strip your harness of anything unneeded in the least, but I always suggest building a harness if you're going to be upgrading your system in this manner
