> P D wrote:
> Even if you gave everyone the same model tester from the same batch run
> , you'd still get different readings .
> There are no two motors that are absolutely identical , let along
> wishing for identical results from testers from one end of the run to
> the other .
> And , that's not considering all the different hands involved in any
> testing or any differences in atmospheric conditions .
> Sure , results may be pretty close , but so are they from different
> brand testers .
> Simply way too many variables .
A nice functioning range is what we are looking for. I'd say 15psi difference is about as much as I'd let slide between my build and someone else's build (they might have used a thicker or thinner base gasket or head gasket.)
but yea, for my own builds and repeat setups (same cylinder, same head, same unmatched cases, same ring gap, same base gasket, etc) i'd be happy to see maybe like 5psi difference between fresh setups
