Re: Who’s a fan of low compression?
> Totally normal JBOT wrote:
> > P D wrote:
> > > > I took a standard long hose compression checker and took off the
> > > crimped
> > > > hose connectors to reveal a hose barb underneath.
> > > > Cut hose and then hose clamp. I also don’t use the brass
> extensions
> > it
> > > > came with. Schrader right into the jug.
> > > I’m going to try this with the hose one I have 🤙🏻 Thanks for the
> pro
> > > tip.
> > Again , Test before and after the 'conversion' .
> > Post the results , please . ;)
> Again, I’m giving you the results. Jesus. I tested it years ago. I’ve
> been using this for like 10 years.
> It was about 20% off.
> If you want exacts go mod one for fucks sake
I know what you told us . And, I appreciate your sharing your experiences .
No offense meant .
I'm simply looking for a second 'opinion' . 2 step verification kinda thing . ;)
> experiences .
> No offense meant .
> thing . ;)
We could all just get the same Stens brand tester and then our data will all be "zeroed" to the same place and your numbers and my numbers would actually be comparable
Totally normal JBOT /
> > > > crimped
> > extensions
> > > it
> > pro
> > > > tip.
> experiences .
> No offense meant .
> thing . ;)
I hate you because you put the idea in my head that I might be wrong, which I might be but I don’t think I am. But then I obsess and am like, “well am I wrong?” Cuz I’m cursed with being a libra. And now today I have to put a long fucking hose back onto this thing to see if I’m right or wrong. Fuck you
> or wrong. Fuck you
LOL . Sorry , I didn't mean for you to doubt yourself .
And , I know about Libras . I'm married to one . ;)
Dirty30 Dillon /
I'm going to grab one when I have the chance. Much like the TrailTech CHT, having a universal baseline would be super useful. We can all chime in on CHT through a TT gauge/similar, but there's always people trying to chat about temps after using a infrared meter or some meat thermo.
Standardizing measurements/methods is the way to go.
IF the tester has a 1-way (ie schrader) valve then there would be an offset to the reading equal to the cracking pressure of that valve. i think for most schrader springs that's in the <5psi range. in this application the lowest spring rate would be best.
if that valve is as close to the cylinder as possible (on the plug adapter?) then the ultimate hose length/volume wouldn't matter.. but you WOULD have to make sure you fully pressurized the hose by turning the engine over enough.
if that valve is instead at the gauge, and you have a long length (volume) hose, then your accuracy will suffer, as you are adding the volume of the hose to the combustion chamber.
if you don't have a valve, you don't have a choice... as short as possible is the only way.
My hose comp gauge read 20 psi higher than Snordley’s homemade Johnny
> the
> > > > > crimped
> > > extensions
> > > > it
> the
> > > pro
> > > > > tip.
> I’ve
> > experiences .
> > No offense meant .
> > thing . ;)
> or wrong. Fuck you
Funny shit here! Ive always liked you JB without really knowing why until now. Are you a left handed Libra? Lefties are in their right frame of mind. (edited)
> of mind.
please trim down quotes like I just did when i quoted you here.
must be a libra thing.
as a leo, I wouldn't get it.
I’m righty tighty.
Left handers are soulless monsters
Obvious Leo is obvious
> I’m righty tighty.
Dont forget that!
> frame
> > of mind.
Na, fuck you. (edited)
> live ɘvil wrote:
> Na, fuck you.
> LSLB RXb wrote:
> > live ɘvil wrote:
> > Na, fuck you.
I love ya any ways
So when I’m wrong I’m wrong I guess
Tested new hose approx 2.5in from Oring on the plug adapter to the dial of the compression gauge.
Read 132ish and stopped climbing at
Tested another hose at 12in with the same as above
Read 145ish before it stopped climbing
These are done cold, open throttle pullstarts with as many as it took until no more pressure.
So it’s opposite what I thought. I think the 150psi air compressor hose might be swelling due the the pressure enough to overpump it where it actually adds false extra pressure in the hose kinda like an air spring, but fuck all if I know.
Oh and 1/8npt gauges or fittings can literally thread into 1/4 ID rubber air compressor hose. Just clamp it and no leaks.
Cool!
I think all you've proven is that compression testers aren't a great absolute measurement for tuning and setup purposes, but I'm glad (some of) the laws of physics aren't being broken in your shop. I've also noticed that after a bunch of cranking engines will get moistened with fuel and oil and read higher compression.
If you have a tester that you use and can get repeatable measurements that kinda help you gauge relatively one setup to another, which it sounds like you're doing, that's probably good but saying stuff like '135 is better than 150' across the board doesn't work for everyone.
> Graham Motzing wrote:
> Cool!
so wait, Graham, are you saying we should all buy the Stens 752-311 Compression Tester so we can all have comparable data??
^ That is exactly what Graham is saying
> > Cool!
Yes, until someone ports their exhaust and ruins it for everyone.
porting...is FORBIDDEN
(edited)
when I deployed last year, we had a group chat. My nickname was meatwad.
I've only used the hi-hi comp heads from treats on any moped I've owned. The compression may be a bit too much but it does make a bit of a difference.
> Ah man I just wrote this on that thread about the eurokit, then I was
> like 'nobody wants to hear an old man ranting about low compression' so
> I didn't post it.
> Yeah especially on big over square setups, I don't really have a good
> reason to explain it but I'll think about it. It seems like on the
> hobbit and v1 especially, with the 47+ mm kits, letting them get through
> the lower rpm with lower load and bmep.
> It's always better for the combustion process to get an earlier spark
> event and have everything fully burn, I think the short stroke makes
> things happen faster, and it takes longer to propagate the flame front
> across a bigger bore, so lower compression kinda softens things up.
> Makes it so it's not so violent when it does hit, so instead of putting
> all that extra heat into the piston and head and detonation, it's
> pushing the piston down. You can kinda feel it like smoothly building
> pressure on each hit rather than slamming hard, maybe? Maybe I'm nuts? I
> don't know.
> Big dome, tight narrow squish, like less than 40%, push the timing as
> hard as you can and pound fuel to the fucker, sure to blast.
Old men don't grow old by being stupid, don't be afraid to share the smarts, know many will not listen, but if they make it to where you are they MAY remember what you said. :)
Alan Jackson /
at least ive discovered another possible reason why my thought processes work as they do
libra here too.
Libras always have something witty to say, making them great conversationalists. ...
Librans crave for attention and will get upset if they are ignored.......
Librans usually die.......
Astrological signs: the only tuning data less relevant than compression pressure
