😶‍🌫️ something new (dirtped 3.2 )
Incelforlifebaby!hotandhorny69 646260 /
The jack shaft is on back order! Hopefully it ships this week
Re: 😶‍🌫️ something new (dirtped 3.2 )
Eric Davenport /
What is that pulley?
sick paint
I like this.
Looks like a comet style series 20 or 30 they come in 6 or 7" diameter if that's what it is.
Yea it’s the rear torque converter and mounted it on a 5/8” jack shaft. Did anyone notice the centrifugal clutch?
If a girls been with only girls then she’s a virgin in my eyes….lol (edited)
It’s so bad! It’s geared so high i think
The clutch is for a four stroke, so I presume it engages at a low rpm (2,000rpms). It basically engaging at idle and I’m not getting it into the power band first.
Going to cut some springs. I’m worried the clutch is going to get burnt up because four strokes don’t spin at 11,000rpms. The clutch got fucking hot!!
I like the idea keep up with the updates. (edited)
> hot!!
Get you a Noram clutch. They are WAY better, adjustable shoes so you can dial in how hard it grabs and two spring style so you can easily set stall speed.
https://www.msquaredkarting.com/store/parts-and-accessories/clutches/noram-clutches-and-accessories/
If your running a 5/8" Jack shaft I have a bushing somewhere in my stash so you can put the 3/4 clutch on the 5/8 shaft. If your running the 3/4 Jack shaft then you good 👍 (edited)
Yea the clutch sucks!
> burnt
> fucking
> > hot!!
> stall speed.
I need it keyed?
The clutch just slips the entire time!?
I highly doubt that the set up is applying so much torque the clutch cant grab?
I’m really not interested in buying a expensive disc clutch…fuck
Going to weld the drum to the jack shaft
! 🤞 (edited)
> rpm
> into
> > burnt
> > fucking
> > > hot!!
> can
> > stall speed.
> stash
> 3/4
> I need it keyed?
It has a slot in it and the key for it is rectangle instead of square.
https://www.amazon.com/dp/B08FHQW2F4/
Here's a link to basically what I have.
I still need to add a needle bearing to the torque converter!
It looks cool! No torque! Gearing is all fucked up, way to high. I need another jack shaft to down gear but I can’t find a way to make that happen!
Are you running the Moby rear sprocket? If so is it a 56? What front sprocket? Kinda looks like your running the freewheel sprocket? If so flip the rear tire so the big sprocket will be on the other side. (edited)
Yes 56 tooth ( photo is with wheeled flipped/“wrong”) Front is 11!
The clutch just slips, I tryed going down a hill and it barely helped.
Is the clutch spinning in the direction it was designed to?
> so
Haha I’ll look! Omg I hope not
> front
> > so
> helped.
NAw we good!
My only option is to run a smaller wheel like a tomos or make a different swing arm!
I’m going to see what a Tomos wheel looks like, then make a jackshaft with 50% decrease in rpm.
Look at a dual variated Peugeot.
Same concept.
Since the rear pulley is now way smaller than a normal french rear pulley you need to gear down somehow.
