Re: MVT premium CDI setup in 2021 - 103
Scottee doesn't know. /
> todd amundson wrote:
> When I set mine up, no matter what motor, the idle is high as fuck. Then
> all of the sudden it’ll drop and not spin fast enough to keep idle
> constant. Motor dies eventually after dropping into the low rpm mode.
> Super shity I can’t get this top of the line ignition off of the shelf.
> I’ve sent it packing from 0 to 4mm BTDC and same low idle condition
> continues. I’m going print out your diagram and see if I was chasing my
> tail all those days but I promise I’ve tried everything. Good topic,
> fucked components?
Hopefully i can get my radiator mounted. and get alittle more into the idle and tuning. mines set at TDC assuming its preset to be pre-retarded 1.5mm. and i a ran it for a few seconds without any water and seemed ok.
all in good time. ill keep updates
