Re: MVT premium CDI setup in 2021 - 103
L e e /
Grounding the blue wire should limit rpm to like 9500 or 9000 or something like that.
I think I just lined up the red mark on the flywheel to the stator and it worked (at TDC I believe, which is not the same as an hpi).
Just double check with a timing light before running it so it doesn't go boom. (edited)
