Re: Diode Substitute
🇮🇹💦 Of the Loin /
Diodes are categorized generally by a) voltage drop which is generally determined by b) the metal composition of the diode.
In general anything that's 0.7 or 0.5v forward voltage drop is as close as you can get to "standard" as possible. The lower the voltage drop the better.
I know of some beefy 0.3v shottky diodes that I like to use but not necessary for this scenario
