> Toledo Riot wrote:
> > P D wrote:
> > I'm sure a hole could be drilled in that 60 dollar small end . ;)
> I was just thinking the same exact thing
> Honestly, even on some of my real fast builds, I use the stock crank,
> its help up at 57mph with no issues
> the last Artek crank I used the conrod was 4-6mm longer then stock, so
> on the stroke it was like 2ish mm longer? Created a bunch of headaches,
> buuuut the other Artek crank Im running was perfect, so a drop in option
> would be nice...
> Or maybe its time to use that Malossi stroker crank I have laying
> around.....
If the artek conrod was longer the stroke should still be the same though?
Isn't that what the malossi crank is, longer conrod but same stroke to help vibrations?
