> P D wrote:
> I'm sure a hole could be drilled in that 60 dollar small end . ;)
I was just thinking the same exact thing
Honestly, even on some of my real fast builds, I use the stock crank, its help up at 57mph with no issues
the last Artek crank I used the conrod was 4-6mm longer then stock, so on the stroke it was like 2ish mm longer? Created a bunch of headaches, buuuut the other Artek crank Im running was perfect, so a drop in option would be nice...
Or maybe its time to use that Malossi stroker crank I have laying around.....
