You want to make sure your intake manifold inner diameter is bigger than 21mm. Also double check the throttle cable & make sure that your throttle slide actually opens completely at full throttle. I suspect JBot is correct about being geared too tall. There's also rumors about Tomos CDI's being rev limited. Can any Tomos dudes confirm or deny this??
