Re: PIAGGIO AC LC variator help..
todd amundson /
The top crank works on the crank that’s pictured first in the topic. The problem is going to be what motor/bike it’s mounted on. That crankshaft above has splines that are cut flat, therefore the variator can only be mounted within a predetermined section of the shaft. I tried a typhoon crank in a variant engine. The variator wouldn’t sit on the shaft/crank where it’s needed. The fact that the splines are only on the tip and far inbound limits you to OEM mounting.
  PIAGGIO AC LC variator help..Topic by: Alex Hedrick Alex Hedrick 11/03/21 06:56PM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/03/21 08:31PM
  Re: PIAGGIO AC LC variator help..Re: Alex Hedrick Alex Hedrick 11/04/21 12:57AM
  Re: PIAGGIO AC LC variator help..Re: Dirty30 Dillon Dirty30 Dillon 11/04/21 09:37AM
  Re: PIAGGIO AC LC variator help..Re: Alex Hedrick Alex Hedrick 11/04/21 04:02PM
  Re: PIAGGIO AC LC variator help..Re: Totally normal JBOT Totally normal JBOT 11/04/21 08:15PM
  Re: PIAGGIO AC LC variator help..Re: Dirty30 Dillon Dirty30 Dillon 11/05/21 12:57AM
  Re: PIAGGIO AC LC variator help..Re: P D P D 11/04/21 11:00AM
  Re: PIAGGIO AC LC variator help..Re: Nick MBC Nick MBC 11/04/21 11:19AM
  Re: PIAGGIO AC LC variator help..Re: EH FCC of the QCB EH FCC of the QCB 11/04/21 07:25PM
  Re: PIAGGIO AC LC variator help..Re: Jackerz ! Jackerz ! 11/04/21 10:20PM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/04/21 10:54PM
  Re: PIAGGIO AC LC variator help..Re: jordan * jordan * 11/03/21 09:46PM
  Re: PIAGGIO AC LC variator help..Re: Alex Hedrick Alex Hedrick 11/04/21 01:04AM
  Re: PIAGGIO AC LC variator help..Re: jordan * jordan * 11/05/21 07:21AM
  Re: PIAGGIO AC LC variator help..Re: todd amundson todd amundson 11/04/21 11:08AM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/04/21 12:09PM
  Re: PIAGGIO AC LC variator help..Re: Alex Hedrick Alex Hedrick 11/04/21 04:08PM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/04/21 10:59PM
  Re: PIAGGIO AC LC variator help..Re: Joel P Joel P 11/04/21 09:45PM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/04/21 10:57PM
  Re: PIAGGIO AC LC variator help..Re: b to the eff b to the eff 11/04/21 10:56PM
  Re: PIAGGIO AC LC variator help..Re: Kevin Bishop Kevin Bishop 11/06/21 10:45AM
  Re: PIAGGIO AC LC variator help..Re: EH FCC of the QCB EH FCC of the QCB 11/06/21 10:51AM
