Re: Za50 intake
Probably Fred /
When servicing the trans on the bike the Inside parts do hang down a bit
I just move the rear wheel if cover hung up on that main gear bearing and or turn flywheel if hung on the clutch bell bearing but for me most times it’s main gear hanging down a mm.
Just like two weeks ago when I took apart the transmission on my gila magnum because I felt excess vibration.
My my two speed driving plate the gear came loose
and also damaged the thrust washer,
I glued the gear back on the drive plate and put a new thrust washer in. When putting on the sidecover on it hung up a little bit so I had to move the rear wheel and then it popped all the way in,
  Za50 intakeTopic by: Chad Tufts Chad Tufts 11/01/21 12:28AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 12:29AM
  Re: Za50 intakeRe: Jacob Fulton Jacob Fulton 11/01/21 01:42AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 02:51AM
  Re: Za50 intakeRe: Stefan Josheski Stefan Josheski 11/01/21 03:11AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:28AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/01/21 06:00PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 07:15PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:52PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 12:34PM
  Re: Za50 intakeRe: Mike Boyd Mike Boyd 11/05/21 03:39PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/05/21 04:42PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 05:03PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/02/21 12:42PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/21/21 12:36AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 11:17PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 03:27PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/21/21 12:04AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/21/21 03:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 12:53AM
  Re: Za50 intakeRe: Taylor King Taylor King 11/02/21 08:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/03/21 11:47PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/04/21 01:29PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/04/21 03:13PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/04/21 06:47PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/05/21 05:53PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:48PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:43PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/23/21 08:11PM
