Re: Za50 intake
Graham Motzing /
I know it's kind of dumb but this is one reason that I really like to pull the motor for this job there are a few places that clips and shims like to get hung up on the crankshaft when you are working on the motor in a vertical orientation.
The shimming should not have changed from what you did so take it all apart and pay really close attention when you are sliding the splined washers that go between the clutches on the crankshaft.
It could be a few different things but the most likely culprit is that the splined washer that goes against the second gear clutch didn't set into place quite right and it is bound up. You can give the clutches a little wiggle by hand and feel then get tight as the nut gets tight on the crank, but the second gear clutch should still spin freely.
You can also turn the flywheel on one side as you tighten up the side cover to identify binding due to insufficient end play clearances .
You really got to pay attention as you put these together and make sure everything is settled into place. Print out the page from the manual and make sure all the shims and stuff are in the right places.
  Za50 intakeTopic by: Chad Tufts Chad Tufts 11/01/21 12:28AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 12:29AM
  Re: Za50 intakeRe: Jacob Fulton Jacob Fulton 11/01/21 01:42AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 02:51AM
  Re: Za50 intakeRe: Stefan Josheski Stefan Josheski 11/01/21 03:11AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:28AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/01/21 06:00PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 07:15PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:52PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 12:34PM
  Re: Za50 intakeRe: Mike Boyd Mike Boyd 11/05/21 03:39PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/05/21 04:42PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 05:03PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/02/21 12:42PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/21/21 12:36AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 11:17PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 03:27PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/21/21 12:04AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/21/21 03:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 12:53AM
  Re: Za50 intakeRe: Taylor King Taylor King 11/02/21 08:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/03/21 11:47PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/04/21 01:29PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/04/21 03:13PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/04/21 06:47PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/05/21 05:53PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:48PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 03/18/22 08:53PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:43PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/23/21 08:11PM
