Re: Za50 intake
Probably Fred /
That sounds like 1.5 hp specs, pipe and other restrictions, you have work to do.
The Intake hole on hi torque cylinders looks 12mm but it not, measure it you will find they are 14mm+ but you can open it up more easIly
When you remove the cylinder to decarbonize You’ll want to remove the thick 1.5hp head gasket if it has one and put the .2 mm thin one treats sells, then inspect everything like rings, ring gap, cylinder bore etc. then you can dremel intake hole on the outside to at least 15 mm,
The stock tall 14 mm bing Za50 intakes are over 14mm already but you can dremel/bore them to 15 mm and use the 14-15mm carb but you can’t use the stock exhaust pipe or air box because of the restrictions so get a circuit type lowend type pipe and metal mesh filter.
You could follow these directions to get to 2hp if it works/not worth the work as far as I’m concerned, a aftermarket pipe and filter is way more power for less work.
https://www.mopedarmy.com/wiki/Puch_horsepower_differences
If the cylinder and piston are in spec I would run a circuit pipe, metal mesh filter, 14mm bing and intake around 72 jet with 222 atomizer, less jet with 212a atomizer if it works good, possible single embossed ring leaner needle.
If You use 15mm bing then open up intake pipe to 15mm try 78 jet 217 atomizer, I would sand the head flat (it’s like 1.7-2mm) removing compression rings for a bit more power.
If cylinder is out of spec I’d go with the TCCD 50 cc kit and 15 mm bing, 14° timing and 35 tooth rear sprocket
  Za50 intakeTopic by: Chad Tufts Chad Tufts 11/01/21 12:28AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 12:29AM
  Re: Za50 intakeRe: Jacob Fulton Jacob Fulton 11/01/21 01:42AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 02:51AM
  Re: Za50 intakeRe: Stefan Josheski Stefan Josheski 11/01/21 03:11AM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:28AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/01/21 06:00PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 07:15PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/01/21 08:52PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 12:34PM
  Re: Za50 intakeRe: Mike Boyd Mike Boyd 11/05/21 03:39PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/05/21 04:42PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 05:03PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/02/21 12:42PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/21/21 12:36AM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/01/21 11:17PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 03:27PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/21/21 12:04AM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/21/21 03:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/02/21 12:53AM
  Re: Za50 intakeRe: Taylor King Taylor King 11/02/21 08:18PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/03/21 11:47PM
  Re: Za50 intakeRe: Graham Motzing Graham Motzing 11/04/21 01:29PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/04/21 03:13PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/04/21 06:47PM
  Re: Za50 intakeRe: Probably Fred Probably Fred 11/05/21 05:53PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:48PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 03/18/22 08:53PM
  Re: Za50 intakeRe: Chad Tufts Chad Tufts 11/05/21 11:43PM
  Re: Za50 intakeRe: b to the eff b to the eff 11/23/21 08:11PM
