> Jack Rutherford wrote:
> I’ve put so many SHA’s on expresses and I don’t remember ever having to
> modify the stock cable. I usually just replace the throttle guide on
> the sha with a shorter one from another carb. I think you did that on
> yours. So modify the carb and not the cable.
> My cables were so seized and full of crud that I couldn’t force lube
> through the cable lube tool into the cable.
I ended up modifying my throttle slide in the carb and went back to the stock cable. My setup is still a bit janky but the moped is running much better now.
