Re: Sha 15.15 on nc50, need help
Jack Rutherford /
I’ve put so many SHA’s on expresses and I don’t remember ever having to modify the stock cable. I usually just replace the throttle guide on the sha with a shorter one from another carb. I think you did that on yours. So modify the carb and not the cable.
My cables were so seized and full of crud that I couldn’t force lube through the cable lube tool into the cable.
