> Jack Rutherford wrote:
> I haven't read PD's thread yet but this could be a job for - Rock Hard
> Old Fuel Line. I save it for just this purpose. Is your throttle cable
> backwards? Looks like you have the carb end going into the handlebars.
> And that throttle cable may be too short unless there's some hidden
> slack. You want it to come over the carb and then go down into it.
> I'd just use the stock express cable. I've used it plenty of times with
> the SHA. I just rescued some frozen cables (all of them) on an express.
> Take the cable off at one end; zip tie it to the bike so it stays
> upright; take some duct tape and make a funnel around the end you took
> off; zip tie the tape at the base of the funnel; spray it full of your
> favorite lube and let it drip down into the cable over night.
The correct end is going to handlebar and and there is plenty of slack. I tried to unsieze the original cable with wd40 but was unsuccessful. I still have a good oem cable, would I need to modify it to use on the dellorto?
